I am Computing Rectified DC Current at constant DC Voltage for 1Ph AC Generator using Periodic model in flux 3D, I would like to know if e.g. Periodicity is 1/4th, 8 pole machine is there, how ever if we have developed model for 2 poles only so Does flux will give me output for complete model of 8 poles or only it will give for modeled geometry of 2 Pole?
then if it is generating 5.3V DC , 2Amps then if we have to consider periodicity output then DC vtg = 5.3*4=21.2 & Amps 2*4 =8 so if I have to make it 14V DC constant then DO I need to adjust my load like to get DC Vtg= 14/4=3.5V so in full model it will be 14V DC, Please suggest
