I am defining a Node and using it as the main node of a Rbody. This Rbody is supposed to connect shell elements with a beam element. The Main node position is important as there is a Spring element that needs to have this node as one of it own. When I define this in Hypermesh, it looks like this:
Red element: RBody
Dark Grey: Beam to be connected with the shells
Green: Shells or Sh3ns
Light Grey: Spring
When I run Radioss with this model, there is no errors. I have Warnings due to the Main Node of some RBodies being connected to an element, but that has not been an issue in the past with other similar configurations. However, when I open Hyperview to see results, I get this:
I am afraid this would change the direction of the Spring force, as it is changing nodes locations.
Does anybody know why I am getting this effect?
Thanks in advance
Diego
