Gear tutorial
harshitpuri
harshitpuri Altair Community Member
edited October 2020 in Community Q&A
i am trying to simulate gears in Radioss.
and found a tutorial of similar case.
<?xml version="1.0" encoding="UTF-8"?>image.thumb.png.575f83c3dad9353c2c75bc5439738b2d.png
But when i import this model, 16 shell node elements are not present.( the one in red and blue)
Also the contact interface referred in model are made from unsupported cards in hypermesh.
How to create 16 shell elements in Radioss and is there any other way to define such contact.?
can we use type 7 or type 19 or type 24 for gear contact?
Welcome!
Answers
  • Pranav Hari
    Pranav Hari Altair Community Member
    edited April 2019
    Hi harshitpuri
    Have you checked this example file from Radioss help? In this example, type 16 & 17 interfaces are used.
  • harshitpuri
    edited April 2019
    I'm referring to same example.
    once i import this model in hm 13.0 The contacts are defined in cards via unsupported cards and Shell node 16 elements are  not visible in hYPERMESH. aLTHOUGH THEY CAN BE SEEN IN HYPERCRASH.
  • Pranav Hari
    edited April 2019
    Hi harshitpuri
    I recommend you to update to the latest version of HyperMesh and try again
Welcome!
Welcome!
