🎉Community Raffle - Win $25
Join and Win
2 contact in succession (optistruct)
VAL1User: "VAL1"
Altair Community Member
Updated by VAL1
I try to analyze press fit with 2 contact object like attached file.
this object has 2 contact surface and there are overlaps.
How to set the condition to analyze in succession?
Eg, first contact 1 is calculated and after the calculation,  contact 2 is calculated
1 - 3 of 31
    Can you try running contact analysis using contact utilities set to MORIENT:OVERLAP.
    VAL1User: "VAL1"
    OP
    Updated by VAL1
    Thank you,
    But what is the difference between MORIENT:OVERLAP and  MORIENT:blank?
    I could do press fit analysis with MORIENT:blank, in this case the overlaps are got rid of at the same time.
    I'd like to get rid of overlap in order...
    Thank you,
    For 'MORIENT: Blank' , it takes default which is open gap i.e. contact interface is open. OVERLAP condition says the slave and master body overlaps.
