2 contact in succession (optistruct)
VAL1
VAL1 Altair Community Member
edited October 2020 in Community Q&A
I try to analyze press fit with 2 contact object like attached file.
this object has 2 contact surface and there are overlaps.
How to set the condition to analyze in succession?
Eg, first contact 1 is calculated and after the calculation,  contact 2 is calculated
Welcome!
Answers
  • Rahul Rajan_21763
    Rahul Rajan_21763 New Altair Community Member
    edited November 2018
    Can you try running contact analysis using contact utilities set to MORIENT:OVERLAP.
  • VAL1
    Thank you,
    But what is the difference between MORIENT:OVERLAP and  MORIENT:blank?
    I could do press fit analysis with MORIENT:blank, in this case the overlaps are got rid of at the same time.
    I'd like to get rid of overlap in order...
  • Nachiket Kadu_22143
    Nachiket Kadu_22143 Altair Community Member
    Thank you,
    For 'MORIENT: Blank' , it takes default which is open gap i.e. contact interface is open. OVERLAP condition says the slave and master body overlaps.
Welcome!
Welcome!
