🎉Community Raffle - Win $25
Join and Win
I got an email from Free Altair Student Edition but can't download the program from the link in the email pls help
User: "Evan Ch"
New Altair Community Member
Updated by Evan Ch
1 - 23 of 231
    User: "Payal Pawar_20288"
    Altair Employee
    Updated by Payal Pawar_20288
    Hi Evan,
    We have sent you alternate download links as a PDF attachment via email. Please check your mailbox.
    P.S. Have you heard about our exciting Altair Global Student Contest? Learn more here - https://web.altair.com/global-student-contest-2023 and enter for a chance to win big!
    User: "AJI AUGUSTINE"
    Updated by AJI AUGUSTINE
    I am also facing the same issue how to solve this.
    Altair Employee
    Hi Aji,
    We have sent you alternate download links as a PDF attachment via email. Please let us know here if the issue persists.
    User: "MOM Veasna"
    Updated by MOM Veasna
    I also face the same issue pls help
    Altair Employee
    Hi,
    User: "MOM Veasna"
    Hi,
    I have downloaded you attached link but still it didnt work because the link is in http protocol. it would be better if you could zip the file or give us another https link. thank you
    Altair Employee
    Hi,
    There shouldn't be any problem downloading the software using the provided links. Could you please specify the exact issue you are facing or share a screenshot of the problem here so that I can take a closer look?
    User: "MOM Veasna"
    Hi,
    I have downloaded the file from given link but it could not be installed. After install upto 100% it didnt show anythings. Thank you for your help
    User: "Flavien.K"
    Updated by Flavien.K
    Hello, same issue for me. I need a link by mail please. Thanks
    Altair Employee
    It is possible that the executable/s was corrupted on download and hence you will need to completely uninstall the software and re-download the executable/s. It is important to first try deleting the downloaded file and downloading it again.
    If you still face issues, to make sure the file is not damaged on download, run an md5 checksum on the downloaded file (just google md5 checksum):
    1. Double click/run the Winmd5 checksum executable (download win md5 a freeware from the internet, please note we cannot be responsible for external content and info)
    2. Select the executable by clicking on the browse button or drag and drop the file into the window
    3. After running the MD5 checksum on your computer, kindly see if your MD5 checksum value matches the original one.
    Refer this article to find the original checksum value -
    https://community.altair.com/community?id=kb_article&sysparm_article=KB0117361&sys_kb_id=5e2d7fc8db8b9950cfd5f6a4e2961925&spa=1
    Altair Employee
    Hi Flavien,
    User: "Khalifa4"
    Updated by Khalifa4
    Hello , I am having the same issue. Pleas I need help. Thanks
    User: "MOM Veasna"
    I have done checksum md5 on my laptop and the file shows (cfbae69055c2710cf0dd66f23ec21cab) which does not match original values
    Altair Employee
    Hi,
    Altair Employee
    Then try to delete the installed software and re-install it again.
    You must use an alternative / better internet connection and provider for example to ensure downloads happen fully and correctly.
    Sufficient disk space for install: Installing the package requires more than 10GB of disk space. The temp space used by the installer will be freed after successful completion of an installation.
    Make sure you have full permissions and rights in the location you are installing.
    Could you please verify whether your system matches the system requirements listed here https://2022.help.altair.com/2022/hwdesktop/altair_help/topics/getting_started/hw_recommendation_certifications_intro_r.htm
    Please refer to this post - https://community.altair.com/community?id=community_question&sys_id=b63faba0dbe6b9d0cfd5f6a4e29619f5
    User: "Anees Alhasi"
    Updated by Anees Alhasi
    Hello , I am having the same issue. Please I need help. Thank you.
    Altair Employee
    Hi Anees,
    We have sent you alternate download links as a PDF attachment via email, please let us know here is the issue persists.
    User: "Mayenk Joshi"
    Updated by Mayenk Joshi
    Facing the same issue. Kindly send alternate download link via email.
    User: "amina licir"
    Updated by amina licir
    hello
    The link don't work, send me another one please
    thanks
    Altair Employee
    Hi Mayenk,
    We have sent you alternate download links as a PDF attachment via email. Please check your mail box.
    Altair Employee
    hello
    thanks
    Hi Amina,
    User: "Mashhunur Rahman"
    Updated by Mashhunur Rahman
    I am facing the same issue. Any alternate download links?
    Altair Employee
    Hi Mashhunur,
    We have sent you alternate download link as a PDF attachment via email. Please let us know here if the issue persists.
