- Double click/run the Winmd5 checksum executable (download win md5 a freeware from the internet, please note we cannot be responsible for external content and info)
- Select the executable by clicking on the browse button or drag and drop the file into the window
- After running the MD5 checksum on your computer, kindly see if your MD5 checksum value matches the original one.
I am also facing the same issue how to solve this.
Hi Aji,
We have sent you alternate download links as a PDF attachment via email. Please let us know here if the issue persists.
P.S. Have you heard about our exciting Altair Global Student Contest? Learn more here - https://web.altair.com/global-student-contest-2023 and enter for a chance to win big!
I also face the same issue pls help
Hi,
We have sent you alternate download links as a PDF attachment via email. Please check your mailbox.
Hi,
I have downloaded you attached link but still it didnt work because the link is in http protocol. it would be better if you could zip the file or give us another https link. thank you
Hi,
There shouldn't be any problem downloading the software using the provided links. Could you please specify the exact issue you are facing or share a screenshot of the problem here so that I can take a closer look?
I have downloaded the file from given link but it could not be installed. After install upto 100% it didnt show anythings. Thank you for your helpHi,
It is possible that the executable/s was corrupted on download and hence you will need to completely uninstall the software and re-download the executable/s. It is important to first try deleting the downloaded file and downloading it again.
If you still face issues, to make sure the file is not damaged on download, run an md5 checksum on the downloaded file (just google md5 checksum):
Refer this article to find the original checksum value -
Hello, same issue for me. I need a link by mail please. Thanks
Hi Flavien,
I have done checksum md5 on my laptop and the file shows (cfbae69055c2710cf0dd66f23ec21cab) which does not match original valuesIt is possible that the executable/s was corrupted on download and hence you will need to completely uninstall the software and re-download the executable/s. It is important to first try deleting the downloaded file and downloading it again.
Hello , I am having the same issue. Pleas I need help. Thanks
Hi,
Then try to delete the installed software and re-install it again.
You must use an alternative / better internet connection and provider for example to ensure downloads happen fully and correctly.
Sufficient disk space for install: Installing the package requires more than 10GB of disk space. The temp space used by the installer will be freed after successful completion of an installation.
Make sure you have full permissions and rights in the location you are installing.
Could you please verify whether your system matches the system requirements listed here https://2022.help.altair.com/2022/hwdesktop/altair_help/topics/getting_started/hw_recommendation_certifications_intro_r.htm
Please refer to this post - https://community.altair.com/community?id=community_question&sys_id=b63faba0dbe6b9d0cfd5f6a4e29619f5
Hello , I am having the same issue. Please I need help. Thank you.
Hi Anees,
We have sent you alternate download links as a PDF attachment via email, please let us know here is the issue persists.
Facing the same issue. Kindly send alternate download link via email.
Hi Mayenk,
We have sent you alternate download links as a PDF attachment via email. Please check your mail box.
hello
The link don't work, send me another one please
thanks
Hi Amina,
I am facing the same issue. Any alternate download links?
Hi Mashhunur,
We have sent you alternate download link as a PDF attachment via email. Please let us know here if the issue persists.
Hi Evan,
