Applied Optimization methods to optistruc
- Objective function is to reduce weight therefor i want to minimize the cross section element such as width and thickness.
- Constrains are stiffness and natural frequency.
Thank so much for your Reply
I have vehicle model which is draw in catia and then i mesh it in hypermesh.
The model is simplified using 3B and ABSC and all beams are thin wall.
I have 500 beam and each beam have 3 parameters to optimize, therefor this is large scale optimization.
I was thinking to apply different numerical and heuristic optimization methods (such as Differential evolution or Particle swarm optimization ...) and find new shape and time benchmark to optimize model.
Thank so much again for quick reply
Best regrads
M.Haghnejat
Could you explain more about your project and what ways are you using to optimize?
Also, please let us know the objective of your design and the constraints.
Best regrads
M.Haghneja
Hi @Haghnejat
Maybe HyperStudy can come in handy.
I will check and let you know as soon as possible.
Best regrads
M.Haghneja
You can refer below Hyperstudy tutorial for your case.
HS-4000: Optimization Method Comparison: Arm Model Shape Optimization
Thank so much for your answer
i sign up now and i will check,
this can help me on the way that i want?
i want to formulate it by software , and as result i have function to work with and find my optimize variables and after i find the optimize value replace it with original value and see the result.
thank so much.
