Altair RISE
Nominate Yourself Now!
Constraint Definition
User: "hiranwale_bharat"
Altair Community Member
Updated by hiranwale_bharat
Hello everyone,
Is it possible to give constraint in only on direction (like the body is constrained in positive x direction but free in negative x direction)?
Regards,
Bharat
1 - 4 of 41
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi Bharat,
    What is the use case and what is the type of analysis you are simulating?
    User: "tinh"
    Updated by tinh
    Hello everyone,
    Regards,
    Bharat
    Hi,
    CGAP elements may help you in this case
    Altair Employee
    All,
    If the physics of the problem allows, here is the procedure to accomplish:
    1. Create a duplicate node and translate it along positive X direction (any small distance.)
    2. Create a gap element such that N1--> N2 is directed in positive X direction. (Make sure to place the gap element in separate collector)
    3. Create a PGAP property and assign it to the CGAP element.
    4. Card edit the PGAP property and enter KB = 2E+20 (basically a high value)
    This will restrict the motion of the node (N1) in positive X direction.
    OP
    Hello Prakash and tinh,
    Thanks for the reply.
    Regards
    Bharat
