🎉Community Raffle - Win $25
Join and Win
Project solution as initial conditions
User: "Sebastian Yang"
Altair Community Member
Updated by Sebastian Yang
Hi,
Two questions about projecting a previous solution as initial condition for the next simulation:
1. Can I do it in Hypermesh? I only know how to do it in AcuCosolue
2. What it does is that it creates a nodal array of node id vs variable value, if I want to project a coarse mesh solution onto a fine mesh, the node ids will not match asI have more elements in the fine mesh, also the node numbering will be different. So this will not work?
Thanks.
1 - 2 of 21
    User: "acupro"
    Altair Employee
    Accepted Answer
    Updated by acupro
    When my problem/mesh with solution, plus the new mesh, are already on a remote machine, I typically use the tool   acuProj   to create the nodal initial condition files - projecting the solution onto a new .crd file.  This will work nicely for your coarse-to-fine mesh study.
    From the AcuSolve Cmd Prompt (or the Linux command) - for usage type
    acuProj -h
    I typically issue this in the directory with the original simulation for which I have results.  Then (assuming my local Acusim.cnf has the problem specified), I just issue acuProj then specify the .crd (or .crd.B) file for the new mesh, already written out from the pre-processor.  For example:
    acuProj -pb old_model -crd ../NewModel/MESH.DIR/new_model.crd
    It will then create the .nic files to be referenced in the input file for the new model.  Move these .nic files to the new problem directory - then edit the input file. For example, in the NODAL_INTITIAL_CONDITION command for velocity:
    NODAL_INITIAL_CONDITION( velocity ) {
        type = nodal_values
        nodal_values = Read( "old_model.vel.nic" )
    OP
    acuProj -h
        type = nodal_values
    Thank you Acupro, that was helpful.
    Initially I thought that I should put the name of my log file as old_model but I was wrong, only the name of the model is needed as the program will search for Acusim.cnf file itself.
