Use of both comma and point as decimal seperator
Sebastian Kuba
Sebastian Kuba Altair Community Member
edited November 2020 in Community Q&A
Dear Altair Team,
I found a strange thing in the Inverse Characterization Tab of the Linear Material Characterization. The "initial values" created out of the data bank are represented with commas as decimal seperator whereas anywhere else the point is used as decimal seperator. I´m not sure if that leads to inconsistencies or wrong results.
See picture attached.
Best regards
Answers
  • Adriano Koga_20259
    Adriano Koga_20259 New Altair Community Member
    edited October 2020
    Hi,
    this is probably related to your system configuration.
    In my MDS i see '.' for everything, which is the prefered option.
  • mertbuldu
    mertbuldu New Altair Community Member
    As Adriano said "." must be. If you change the computer's number settings, all values are "." will come with.
Welcome!
Welcome!
