About master and slave SLIDE contact
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
hello everyone
I am performing Slide contact between the pin and plate forming the revolute joint. in radioss
initially i have performed analysis with pin as MASTER and that plate with SLAVE found ans with stresses at about 200mpa
then i changed the combination with pin as SLAVE and plate as MASTER now i am getting results about 10mpa
so why is this drastic differenece????????????
which one is correct??????????/
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2016
    Hi Sagar,
    In Type 7 contact interface, what is the stiffness formulation you have used?
    Few contact stiffness modelling types uses master and slave stiffness.
Welcome!
Welcome!
