hello everyone
I am performing Slide contact between the pin and plate forming the revolute joint. in radioss
initially i have performed analysis with pin as MASTER and that plate with SLAVE found ans with stresses at about 200mpa
then i changed the combination with pin as SLAVE and plate as MASTER now i am getting results about 10mpa
so why is this drastic differenece????????????
which one is correct??????????/
