Error #1000
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hello everybody, i have an issue with a static linear analysis with contacts. i applied PARAM - FASTCONT in order to linearize contacts but when i start the analysis (in optistruct) the solver gives message:
  *** See next message about line 42 from file:
     C:/Users/Matteo/Desktop/P.A.C/Progetto/analisi test/13 AS conf alta.fem
  'CONTACT        2   SLIDE                                    AUTO0.0'
 *** ERROR # 1000 *** in the input data:
 Incorrect data in field # 4.
does anyone knows how i could fix it? the contact is formed by a wheel that slides on a plane surface.
Thank you
Welcome!
Answers
  • Rahul Rajan_21763
    Rahul Rajan_21763 New Altair Community Member
    edited June 2019
    Please check whether the material property is assigned to the component or not.
  • Mat_80
    Mat_80 Altair Community Member
    edited August 2019
    Hello,  I have a model with linearization contact with a card 'FASTCONT' with type contact 'stick'. I also have to do a normal mode analysis. Is it possible to do with this settings ? I try to do in this way but i get only 7 rigid displacement but i 'need' 8 because i have a cart with two wheels pivoting. Can someone help me ?
    thanks
  • GlizaYuson
    GlizaYuson Altair Community Member
    edited August 2019
    The Event ID 1000 application error is one included in the Event Viewer log when applications crash. Thus, when the error occurs, you can't launch the required program or software might unexpectedly close.Event 1000 application error on Windows 10
  • Rahul Rajan_21763
    edited October 2020
    thanks
    Please refer the comment in below post for FASTCONT.
    https://community.altair.com/community?id=community_question&sys_id=5766803a1b2bd0908017dc61ec4bcb98
Welcome!
Welcome!
