🎉Community Raffle - Win $25
Join and Win
Error #1000
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello everybody, i have an issue with a static linear analysis with contacts. i applied PARAM - FASTCONT in order to linearize contacts but when i start the analysis (in optistruct) the solver gives message:
  *** See next message about line 42 from file:
     C:/Users/Matteo/Desktop/P.A.C/Progetto/analisi test/13 AS conf alta.fem
  'CONTACT        2   SLIDE                                    AUTO0.0'
 *** ERROR # 1000 *** in the input data:
 Incorrect data in field # 4.
does anyone knows how i could fix it? the contact is formed by a wheel that slides on a plane surface.
Thank you
1 - 4 of 41
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Please check whether the material property is assigned to the component or not.
    User: "Mat_80"
    Updated by Mat_80
    Hello,  I have a model with linearization contact with a card 'FASTCONT' with type contact 'stick'. I also have to do a normal mode analysis. Is it possible to do with this settings ? I try to do in this way but i get only 7 rigid displacement but i 'need' 8 because i have a cart with two wheels pivoting. Can someone help me ?
    thanks
    User: "GlizaYuson"
    Updated by GlizaYuson
    The Event ID 1000 application error is one included in the Event Viewer log when applications crash. Thus, when the error occurs, you can't launch the required program or software might unexpectedly close.Event 1000 application error on Windows 10
    thanks
    Please refer the comment in below post for FASTCONT.
    https://community.altair.com/community?id=community_question&sys_id=5766803a1b2bd0908017dc61ec4bcb98
