Hello everybody, i have an issue with a static linear analysis with contacts. i applied PARAM - FASTCONT in order to linearize contacts but when i start the analysis (in optistruct) the solver gives message:
*** See next message about line 42 from file:
C:/Users/Matteo/Desktop/P.A.C/Progetto/analisi test/13 AS conf alta.fem
'CONTACT 2 SLIDE AUTO0.0'
*** ERROR # 1000 *** in the input data:
Incorrect data in field # 4.
does anyone knows how i could fix it? the contact is formed by a wheel that slides on a plane surface.
Thank you
