Altair RISE
Nominate Yourself Now!
creat fixation in hypermesh 13
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
hello
I want to create a setting (fixation) and a force under HyperMesh RADIOSS 13 block 120
how to proceed
thanks
1 - 4 of 41
    Altair Employee
    OP
    Hi,
    From the Utility page, start the BC’s manager.
    Under Create, select type to Boundary conditions to create constraints and select concentrated load to create force
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-60633400-1414491268_thumb.jp
    Altair Employee
    OP
    where is the Utility page ?
    thank you
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    The utility tab should be right next to the model browser tab, in the tab area, to the left of the graphics area,
    <?xml version="1.0" encoding="UTF-8"?>post-4438-0-21437000-1414497660_thumb.jp
    If not you will need to check it in the view menu,
    <?xml version="1.0" encoding="UTF-8"?>post-4438-0-47656400-1414497608_thumb.jp
    Altair Employee
    OP
    ok thanks ,
    where is load steps ?
