hello
I want to create a setting (fixation) and a force under HyperMesh RADIOSS 13 block 120how to proceed
thanks
From the Utility page, start the BC’s manager.
Under Create, select type to Boundary conditions to create constraints and select concentrated load to create force
where is the Utility page ?
thank you
The utility tab should be right next to the model browser tab, in the tab area, to the left of the graphics area,
If not you will need to check it in the view menu,
ok thanks ,
where is load steps ?
