🎉Community Raffle - Win $25
Join and Win
Impact Analysis using HyperMesh & Radioss
User: "Rajesh Shetty_21146"
Altair Community Member
Updated by Rajesh Shetty_21146
Hello all,
I'm performing an impact analysis in HyperWorks using Radioss profile. My query is regarding the postprocessing the damage area in HyperView.
Impact analysis -> impact of a composite plate using spherical steel ball
While setting up the solver deck in HyperMesh (Profile: Radioss), I have used the following control cards to evaluate the damage areas:
/ANIM/BRICK/TENS/DAMA/
/ANIM/BRICK/DAMA/
While postprocessing, in HyperView, I can see only the damaged elements (deleted elements) on the composite plate. I can't see the display of damaged area in the legends. My query is, how to measure the damaged area on the composite plate. Is there any control cards I can use to measure the damaged area ? Can we see the damaged area in the legends ?
Thanking you,
Rajesh
1 - 3 of 31
    User: "Mathis"
    Altair Employee
    Updated by Mathis
    Hi Rajesh,
    /ANIM/BRICK/TENS/DAMA is only compatible with concrete material law (/MAT/LAW24). So it is expected you don't see anything with composite.
    /ANIM/BRICK/DAMA should work if you have a failure criteria defined (like /FAIL/HASHIN for instance).
    In order to answer to you as best as possible could you please answer to the following questions:
    • What is the material law you are using?
    • What is the damage model you are using?
    • What is the element type you are using?
    Thanks !
    Regards,
    Mathis.
    OP
    Hi Rajesh,
    Thanks !
    Regards,
    Mathis.
    Hello Mathis,
    Greetings!
    Thanks a lot for your reply.
    /MAT/LAW25 (COMPSH)
    /FAIL/HASHIN
    BRICK ELEMENTS (HEX8)
    Regards,
    Rajesh
    OP
    Few composite plates are made of only unidirectional or woven plies
    And, few are the combinations of both unidirectional and woven plies
