Impact Analysis using HyperMesh & Radioss
Rajesh Shetty_21146
Rajesh Shetty_21146 Altair Community Member
edited October 2023 in Community Q&A
Hello all,
I'm performing an impact analysis in HyperWorks using Radioss profile. My query is regarding the postprocessing the damage area in HyperView.
Impact analysis -> impact of a composite plate using spherical steel ball
While setting up the solver deck in HyperMesh (Profile: Radioss), I have used the following control cards to evaluate the damage areas:
/ANIM/BRICK/TENS/DAMA/
/ANIM/BRICK/DAMA/
While postprocessing, in HyperView, I can see only the damaged elements (deleted elements) on the composite plate. I can't see the display of damaged area in the legends. My query is, how to measure the damaged area on the composite plate. Is there any control cards I can use to measure the damaged area ? Can we see the damaged area in the legends ?
Thanking you,
Rajesh
Welcome!
Answers
  • Mathis
    Mathis
    Altair Employee
    edited October 2023
    Hi Rajesh,
    /ANIM/BRICK/TENS/DAMA is only compatible with concrete material law (/MAT/LAW24). So it is expected you don't see anything with composite.
    /ANIM/BRICK/DAMA should work if you have a failure criteria defined (like /FAIL/HASHIN for instance).
    In order to answer to you as best as possible could you please answer to the following questions:
    • What is the material law you are using?
    • What is the damage model you are using?
    • What is the element type you are using?
    Thanks !
    Regards,
    Mathis.
  • Rajesh Shetty_21146
    edited October 2023
    Hi Rajesh,
    Thanks !
    Regards,
    Mathis.
    Hello Mathis,
    Greetings!
    Thanks a lot for your reply.
    /MAT/LAW25 (COMPSH)
    /FAIL/HASHIN
    BRICK ELEMENTS (HEX8)
    Regards,
    Rajesh
    edited October 2023
    Few composite plates are made of only unidirectional or woven plies
    And, few are the combinations of both unidirectional and woven plies
Welcome!
Welcome!
