Hello all,
I'm performing an impact analysis in HyperWorks using Radioss profile. My query is regarding the postprocessing the damage area in HyperView.
Impact analysis -> impact of a composite plate using spherical steel ball
While setting up the solver deck in HyperMesh (Profile: Radioss), I have used the following control cards to evaluate the damage areas:
/ANIM/BRICK/TENS/DAMA/
/ANIM/BRICK/DAMA/
While postprocessing, in HyperView, I can see only the damaged elements (deleted elements) on the composite plate. I can't see the display of damaged area in the legends. My query is, how to measure the damaged area on the composite plate. Is there any control cards I can use to measure the damaged area ? Can we see the damaged area in the legends ?
Thanking you,
Rajesh
