Altair RISE
Nominate Yourself Now!
ANSYS Thermal Results in Hyperview
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello -- trying to use Hyperview to look at thermal results from ANSYS. Have done this in the past at my company using P/Thermal (GE code) and now I am working for a different customer who requires ANSYS analysis.
There seems to be no how-tos on the process to view temperature results in Hyperview for .rth files. Has anyone done this before and can help with some basic steps?
1 - 9 of 91
    User: "jakub.ziontek"
    Altair Community Member
    Updated by jakub.ziontek
    I also wanted to ask same question. Why its so hard in hyperview??
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    All,
    Not sure the problems you are facing, are you not seeing the required results in the result type?
    Please see a sample result file with thermal results attached to this post, that I can postprocess easily in HV
    My analysis is stress analysis with temperature and pressure added, than i cant postprocessing temperatures in HV. It is body force card in ansys (BF_TEMP). In ansys it is called 'Body Temperatures'
    no reply on it?
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    Current HyperView does not support BFTEMP as one of thermal result of Ansys.
    We are investigating such issues with Ansys Post processing and these will be fixed in the upcoming patches / releases,
    we regret the inconvenience,
    Supporting BF_TEMP is not supported in HV 13? It would help in work. Now i have to go to ansys post processing all the time when i need to make for example plot temp vs stress....
    Do you predict when BF_TEMP will be supported in HV?
    please answer, above question
    User: "mjohnson"
    Altair Employee
    Updated by mjohnson
    This functionality is available as of version 2021.2. Legacy interface shown at top, and current interface at bottom with nodal temperature plotted.
