ANSYS Thermal Results in Hyperview
Hello -- trying to use Hyperview to look at thermal results from ANSYS. Have done this in the past at my company using P/Thermal (GE code) and now I am working for a different customer who requires ANSYS analysis.
There seems to be no how-tos on the process to view temperature results in Hyperview for .rth files. Has anyone done this before and can help with some basic steps?
All,
Not sure the problems you are facing, are you not seeing the required results in the result type?
Please see a sample result file with thermal results attached to this post, that I can postprocess easily in HV
My analysis is stress analysis with temperature and pressure added, than i cant postprocessing temperatures in HV. It is body force card in ansys (BF_TEMP). In ansys it is called 'Body Temperatures'
Supporting BF_TEMP is not supported in HV 13? It would help in work. Now i have to go to ansys post processing all the time when i need to make for example plot temp vs stress....
I also wanted to ask same question. Why its so hard in hyperview??
