Altair RISE
Nominate Yourself Now!
1D beam element association
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
user profiles: ANSYS
i need to apply beam 188 element for created 1D beam elements and i have already created crossection in hyperbeam, how do i assign that to 1D element.
Very urgent
Thanks in advance
1 - 8 of 81
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi,
    I am not sure where will be assigned beam section (in OS it is assigned to property, but it's not a solver keyword)
    what is your section type?
    There are some property types for beam. Did you try creating it and assign to beam component?
    User: "Sanjay Nainani_20973"
    New Altair Community Member
    Updated by Sanjay Nainani_20973
    Hello,
    In ANSYS profile to assign the element type you need to create ETTYPE of that particular element type and assign it to the respective component.
    Thankyou
    Altair Employee
    OP
    Thanks sanjay,
    But how to create ETTYPE
    Altair Employee
    OP
    @tinh
    am looking for beam 188 element
    User: "tinh"
    Updated by tinh
    Thanks sanjay,
    Go to panel 1D>ET Types
    User: "tinh"
    Updated by tinh
    @tinh
    default elem for bar2 is BEAM188 already
    just create bar2 elements
    if you want to switch, go to panel 1D>elem types, select 1d elems, confirm that 'bar2 = BEAM188' and click update
    Did you create property ?
    Altair Employee
    OP
    @tinh
    I have created beam crossection, now i have to assign that crossection for the line (which is 1D element), how to do this
    User: "tinh"
    Updated by tinh
    what is your section shape? circle, box?
    I don't see anywhere to assign section so maybe you have to input its dimension directly to property card
