user profiles: ANSYS
i need to apply beam 188 element for created 1D beam elements and i have already created crossection in hyperbeam, how do i assign that to 1D element.
Very urgent
Thanks in advance
I am not sure where will be assigned beam section (in OS it is assigned to property, but it's not a solver keyword)
what is your section type?
There are some property types for beam. Did you try creating it and assign to beam component?
In ANSYS profile to assign the element type you need to create ETTYPE of that particular element type and assign it to the respective component.
Thankyou
Thanks sanjay,
But how to create ETTYPE
@tinh
am looking for beam 188 element
Thanks sanjay, But how to create ETTYPE
Go to panel 1D>ET Types
@tinh am looking for beam 188 element
default elem for bar2 is BEAM188 already
just create bar2 elements
if you want to switch, go to panel 1D>elem types, select 1d elems, confirm that 'bar2 = BEAM188' and click update
Did you create property ?
I have created beam crossection, now i have to assign that crossection for the line (which is 1D element), how to do this
what is your section shape? circle, box?
I don't see anywhere to assign section so maybe you have to input its dimension directly to property card
