1 - 8 of
81
am looking for beam 188 element
default elem for bar2 is BEAM188 already
just create bar2 elements
if you want to switch, go to panel 1D>elem types, select 1d elems, confirm that 'bar2 = BEAM188' and click update
Did you create property ?
I have created beam crossection, now i have to assign that crossection for the line (which is 1D element), how to do this
Hi,
I am not sure where will be assigned beam section (in OS it is assigned to property, but it's not a solver keyword)
what is your section type?
There are some property types for beam. Did you try creating it and assign to beam component?
