🎉Community Raffle - Win $25
Join and Win
ERROR # 4965 & ERROR 5905
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
guys, can u help...... how to give self contact for the spring which wouldnt penetrate while doing non-linear analysis...i am hypermesh with opticstrut as slover
https://photos.app.goo.gl/9MARHszowpG7fMJ1A
1 - 3 of 31
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Which version of OptiStruct you are using? Please share the .out file of the run.
    User: "Simon Križnik"
    Updated by Simon Križnik
    Hi @tejas6
    group1 & 2 should be changed from stick to freeze contact.
    Self contact for the spring can be set-up with S2S and CONSLI. However, the model fails to converge beyond 75% with errors:
    *** ERROR # 4965 ***
     Maximum number of time increment cutbacks reached,
     analysis aborted.
     *** ERROR # 5905 ***
     Severe element distortion detected,
     analysis aborted.
    Because the model undergoes geometric and contact nonlinearities it could be solved more computationally efficient with Radioss explicit solver.
    If the solver reports excessive mesh distortion, consider the following reasons:
    • Excessive or unrealistic loading
    • Over-constrained FE model
    • Inconsistent unit system between model, material and/or loading that lead to excessive deformation
    Reviewing the last non-converged iteration in HyperView will help
    Please refer to attached model from OptiStruct example guide.
