guys, can u help...... how to give self contact for the spring which wouldnt penetrate while doing non-linear analysis...i am hypermesh with opticstrut as slover
https://photos.app.goo.gl/9MARHszowpG7fMJ1A
Which version of OptiStruct you are using? Please share the .out file of the run.
Hi @tejas6
group1 & 2 should be changed from stick to freeze contact.
Self contact for the spring can be set-up with S2S and CONSLI. However, the model fails to converge beyond 75% with errors:
*** ERROR # 4965 *** Maximum number of time increment cutbacks reached, analysis aborted. *** ERROR # 5905 *** Severe element distortion detected, analysis aborted.
Because the model undergoes geometric and contact nonlinearities it could be solved more computationally efficient with Radioss explicit solver.
If the solver reports excessive mesh distortion, consider the following reasons:
Reviewing the last non-converged iteration in HyperView will help
Please refer to attached model from OptiStruct example guide.
