ERROR # 4965 & ERROR 5905
guys, can u help...... how to give self contact for the spring which wouldnt penetrate while doing non-linear analysis...i am hypermesh with opticstrut as slover
https://photos.app.goo.gl/9MARHszowpG7fMJ1A
Answers
Which version of OptiStruct you are using? Please share the .out file of the run.
0 -
Hi @tejas6
group1 & 2 should be changed from stick to freeze contact.
Self contact for the spring can be set-up with S2S and CONSLI. However, the model fails to converge beyond 75% with errors:
*** ERROR # 4965 ***
Maximum number of time increment cutbacks reached,
analysis aborted.
*** ERROR # 5905 ***
Severe element distortion detected,
analysis aborted.Because the model undergoes geometric and contact nonlinearities it could be solved more computationally efficient with Radioss explicit solver.
0 -
If the solver reports excessive mesh distortion, consider the following reasons:
- Excessive or unrealistic loading
- Over-constrained FE model
- Inconsistent unit system between model, material and/or loading that lead to excessive deformation
Reviewing the last non-converged iteration in HyperView will help
Please refer to attached model from OptiStruct example guide.
0
