🎉Community Raffle - Win $25
Join and Win
RADIOSS ENGINE FILE TERMS
User: "Amith Anoop Kumar"
Altair Community Member
Updated by Amith Anoop Kumar
Can anyone please explain what this terms are. This is a snipshot from a radioss engine file.
Also one more thing do we determine the time step for an analysis using the standard formula or is through a trial and error method of different time steps
Thanks in advance
1 - 1 of 11
    User: "Adriano_Koga"
    Altair Employee
    Accepted Answer
    Updated by Adriano_Koga
    I believe this might be explained somewhere in Radioss training material or documentation.
    Anyway, radioss runs for many cycles. You can choose the frequency for it to show you what is going on in each cycle/timestep
    NC is the current number of cycles
    T is the current run time
    DT is the timestep of this particular cycle
    Error is the percentage error of the solution
    DM/M is added mass (delta mass/total mass).
