1 - 3 of
31
I have requested restart file. I am looking for procedure using which I can restart my run on HPC cluster as user interface for HPC cluster is different.
I think you can submit your _0002.rad as job to run (restart engine, can be a straight copy of your _0001.rad if this is just restarting a stopped job), and the _0001_000n.rst files from the first run as 'Additional Files' You will need to run on the same number of cpu as the original job
You could only restart an analysis if you have requeested restart files to be written upfront.
Please, take a look below.
https://2021.help.altair.com/2021/hwsolvers/rad/topics/solvers/rad/faq_rad_restart_r.htm
