how to improve 3D Meshing Quality and Alternative Approaches for Topology Optimization Results
Reza Karshenas
Reza Karshenas Altair Community Member
edited August 2023 in Community Q&A
hi,
does anyone know how to improve the quality of 3D meshing? Well, Tetra remesh doesn't help, it doesn't make any difference. I would like to know in general what alternative I have if I can't get a good mesh after topology optimization. if there is no more possibility, how can I get a solid out of meshing and again mesh it?
Answers
  • RobHoglund
    RobHoglund
    Altair Employee
    edited August 2023
    Hi Reza,
    There are a few different options in HyperWorks you can use to take the results forward after running topology optimization.
    For a full redesign and validation, I would suggest using Inspire.  You can use Altair Inspire to fit PolyNurbs over the optimized result from a topology optimization (starting from the STL iso-surface contour).  This generates a smooth CAD profile over the optimized results.  This is generally what we suggest once you get some optimized result from OptiStruct and want to get a solid CAD interpretation from the design and then remesh and reanalyze it with Hypermesh or Inspire depending on the level of detail you need.
    Thanks,
    Rob H.
  • Reza Karshenas
    edited August 2023
    Hi Robert
    thanks for tipps. got it.
    best regards, Reza
Welcome!
Welcome!
