🎉Community Raffle - Win $25
Join and Win
How to import CATIA Part files
I created python script using SimLab before I use Hyperstudy.
And I played the script to check some errors, but It worked successfully.
However, whenever I use Hyperstudy, it doesen't work.
So I checked script log file, and I found that the CATIA model(.Part) didn't import.
But the model successfully imported when I played the script on SimLab.
How can I import model file on Hyperstudy? What was the problem?image
1 - 13 of 131
    Hi GyeongJun Lee,
    Can you please place all the files related to the script in a single folder and then try?
    Basically the CAD file, the script file and any other files being used in the script, please keep them in the same folder and similarly edit the relative path and then try.
    Please let me know if you still face the issue.
    GyeongJun LeeUser: "GyeongJun Lee"
    Altair Community Member
    OP
    Updated by GyeongJun Lee
    Hi GyeongJun Lee,
    Hi, Aniruddha.
    Placing the script file with simlab result file isn't possible because of some reasons.
    So I separated the files
    OP
    Hi, Aniruddha.
    I placed all the files related the script excluding hyperstudy file.
    But Importing Catia was failed
    Hi, Aniruddha.
    Hello GyeongJun Lee,
    Do you have a design parameters in the CATIA model?
    I believe you are doing a DOE study with the HyperStudy. Are you going to change the CAD design parameters or SimLab parameters for DOE?
    If possible, could you please share the script and model? Will check and let you know.
    Thanks & Regards,
    Santhoshkumar
    OP
    Thanks & Regards,
    Santhoshkumar
    Hello Santhoshkumar,
    The script and the model are here.
    Thank you for sharing the files.
    I will check and get back you.
    Thanks & Regards,
    Santhoshkumar
    Thanks & Regards,
    Santhoshkumar
    Can you also share your .hstx file? You can create it by going to File > Export. When running in SimLab by itself you haven't had any problems?
    Kind regards,
    Marc
    OP
    Kind regards,
    Marc
    Hello Marc,
    The script hasn't had any problems when it run in SimLab by itself.
    hstx file is here.
    Hello Marc,
    hstx file is here.
    I can reproduce the issue which you have reported.
    While running the script through HST, the CATIA import is not working.
    Our development team is looking into this. Will get back you once they fix.
    I have noticed one more thing in the CATIA file which you have shared. The publications (groups) are not imported in SimLab. Further investigated and found that SL_PUB is not added to the created publications. After adding the SL_PUB, the publications are imported properly.
    Please find the attached SimLab help page regarding the CATIA publications for your reference.
    Please find the attached updated CATIA file.
    Thanks & Regards,
    Santhoshkumar.
    OP
    Thanks & Regards,
    Santhoshkumar.
    I installed the latest version, SimLab 2024 and Hyperstudy 2024, because I think they don't have this problem about CATIA import.
    But while I was running the script through HST 2024, the CATIA import wasn't working.
    I hope that your team find some reason of this problem.
    Thanks for your advise and your help.
    Sorry for the delay in my response.
    Finally, I have identified the reason for the CATIA import failure in HyperStudy with the help of development team.
    The reason for the failure is, In the CATIA model, the following 2 parameters are with expressions. SimLab will not allow to regenerate the CATIA parameters with expression. In HyperStudy, all the Parameters are considered for the DOE run. Due to that the CATIA import failed.
    On SimLab side, the CATIA parameters with expression should not import inside SimLab. We will fix this one.
    As a workaround, kindly delete the below 2 parameters in "script_Params.xml" file. After that, run the script in HyperStudy. It will work fine.
    Please find the attached updated "script_Params.xml" file.
    Note: By changing the Parameter value for "L" & "N", the updated value will be considered in the "Wx" and "Wy" parameters.
    Please try this and let me know.
    Thanks & Regards,
    Santhoshkumar
    OP
    Thanks & Regards,
    Santhoshkumar
    As soon as I saw your comment, I was running the script immediately.
    It was successfully done! There were no problems like before.
    Thanks for your team's help.
    Thank you for confirming very quickly. :)
    Feel free to reach me if you have any queries.
    Thanks and Regards,
    Santhoshkumar
