Job Launcher in Acusolve doesn't work
User: "EnDF"
Altair Community Member
Updated by EnDF
Hi everybody,
I have a problem with AcuSolve from Hyperworks. When I want to launch the Solver Job Launcher the 'solver exec dir' is empty, but in another topic of this forum I saw that a possible solution is to insert the installation path of acusolve (as you can see in the image below).
I can't press the button Launch..
Instead, if I export the Solver Deck in AcuConsole ,resetting some data, the solution run.
What could be the problem?
thanks in advance
1 - 8 of 81
    User: "EnDF"
    OP
    Updated by EnDF
    No one can help me?
    User: "acupro"
    Altair Employee
    Updated by acupro
    You many need to specify the 'Output format' to something other than 'None'.  Does your version have the 'AcuSolve Job Launcher' instead?
    User: "EnDF"
    OP
    Updated by EnDF
    Dear acupro, thanks for your response
    I have the academic version and I have this one in the image
    joblauncher.png.9d00a93582f584c46dfedcbdea492e80.png.
    Where is the acusolve job launcher?
    User: "ydigit"
    Altair Employee
    Updated by ydigit
    The AcuSolve Job Launcher should be available in your Start > Program > Altair 2019> AcuSolve folder, like the screenshot below.
    OR even using the Search  for Job Launcher on Windows 10 should reveal it.
    User: "EnDF"
    OP
    Updated by EnDF
    thank you, ydigit, for your help.
    best regards
    User: "acupro"
    Altair Employee
    Updated by acupro
    My previous comment about 'Output Format' will not resolve anything.  That just means if you want to translate the output results to a format other than the native AcuSolve format, after the job is complete - so None is fine.
    User: "EnDF"
    OP
    Updated by EnDF
    Thank you acupro for your help, I think I understand.
    User: "Junta_20361"
    New Altair Community Member
    Updated by Junta_20361
    Hi everybody,
    <?xml version="1.0" encoding="UTF-8"?>topic.png.77e4dd86f8ae7b29c0219fd647b68911.png
    thanks in advance
    hi,
    did you solve the problem?
    for my experience, the reason is very simple.
    the problem directory contains 'space' in the path. you need to remove it.
    no space are allowed in the folder path :D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
