Job Launcher in Acusolve doesn't work
Hi everybody,
I have a problem with AcuSolve from Hyperworks. When I want to launch the Solver Job Launcher the 'solver exec dir' is empty, but in another topic of this forum I saw that a possible solution is to insert the installation path of acusolve (as you can see in the image below).
I can't press the button Launch..
Instead, if I export the Solver Deck in AcuConsole ,resetting some data, the solution run.
What could be the problem?
thanks in advance
Hi everybody,
thanks in advance
hi,
did you solve the problem?
for my experience, the reason is very simple.
the problem directory contains 'space' in the path. you need to remove it.
no space are allowed in the folder path /emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
No one can help me?
