Job Launcher in Acusolve doesn't work
EnDF
EnDF Altair Community Member
edited October 2020 in Community Q&A
Hi everybody,
I have a problem with AcuSolve from Hyperworks. When I want to launch the Solver Job Launcher the 'solver exec dir' is empty, but in another topic of this forum I saw that a possible solution is to insert the installation path of acusolve (as you can see in the image below).
I can't press the button Launch..
Instead, if I export the Solver Deck in AcuConsole ,resetting some data, the solution run.
What could be the problem?
thanks in advance
Welcome!
Answers
  • EnDF
    edited April 2020
    No one can help me?
  • acupro
    acupro
    Altair Employee
    edited April 2020
    You many need to specify the 'Output format' to something other than 'None'.  Does your version have the 'AcuSolve Job Launcher' instead?
  • EnDF
    edited April 2020
    Dear acupro, thanks for your response
    I have the academic version and I have this one in the image
    joblauncher.png.9d00a93582f584c46dfedcbdea492e80.png.
    Where is the acusolve job launcher?
  • ydigit
    ydigit
    Altair Employee
    edited April 2020
    The AcuSolve Job Launcher should be available in your Start > Program > Altair 2019> AcuSolve folder, like the screenshot below.
    OR even using the Search  for Job Launcher on Windows 10 should reveal it.
  • EnDF
    edited April 2020
    thank you, ydigit, for your help.
    best regards
  • acupro
    acupro
    Altair Employee
    edited April 2020
    My previous comment about 'Output Format' will not resolve anything.  That just means if you want to translate the output results to a format other than the native AcuSolve format, after the job is complete - so None is fine.
  • EnDF
    edited April 2020
    Thank you acupro for your help, I think I understand.
  • Junta_20361
    Junta_20361 New Altair Community Member
    edited May 2020
    Hi everybody,
    <?xml version="1.0" encoding="UTF-8"?>topic.png.77e4dd86f8ae7b29c0219fd647b68911.png
    thanks in advance
    hi,
    did you solve the problem?
    for my experience, the reason is very simple.
    the problem directory contains 'space' in the path. you need to remove it.
    no space are allowed in the folder path :D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
Welcome!
Welcome!
