Error ID 197 Reference direction composites
Hi all,
I'm facing a problem I can't fix.
When I want to perform my dynamic analysis, I get 8769 errors like below :
ERROR ID: 197
REFERENCE DIRECTION IS ALMOST NORMAL TO SHELL ID=54115
Could you please help me to fix it ?
For confidential issues, I can't illustrate my model...
Best regards,
Raphael
1 - 5 of
51
when assigning material orientation, make sure the direction is not perpendicular to shell elements, whose IDs are reported with the error.
Hi Raphael,
Do you have /PROP/TYPE9 (Orthotropic Shell Property) in your model?.
If so, edit (Right click on Blank property and select card edit) the blank property /PROP/SH_ORTH card and specify dummy values for Vx, Vy and Vz as shown below and try running the same.
