Error ID 197 Reference direction composites
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hi all,
I'm facing a problem I can't fix.
When I want to perform my dynamic analysis, I get 8769 errors like below :
ERROR ID: 197
REFERENCE DIRECTION IS ALMOST NORMAL TO SHELL ID=54115
Could you please help me to fix it ?
For confidential issues, I can't illustrate my model...
Best regards,
Raphael
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited April 2018
    Hi Raphael,
    Do you have /PROP/TYPE9 (Orthotropic Shell Property) in your model?.
    If so, edit (Right click on Blank property and select card edit)  the blank property /PROP/SH_ORTH card and specify dummy values for Vx, Vy and Vz as shown below and try running the same.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited April 2018
    Hi Georges,
    No I only have a P17_STACK property in my model. I've got 8 plies, 1 associated laminate then a stack property.
    I tried running with those values assigned to the reference vector, but I still not working.
    Do you have any other idea ?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited April 2018
    Hi Raphael,
    If possible please share the model file through the secure dropbox so that we can review and help you to sort out the issue, which will be the best option.
    Else share the starter out file.
  • xrek
    xrek Altair Community Member
    edited August 2020
    Hello,
    any insight on how this issue was resolved?
    Thank you
  • Simon Križnik
    Simon Križnik Altair Community Member
    edited August 2020
    /profile/95777-xrek/?do=hovercard' data-mentionid='95777' href='<___base_url___>/profile/95777-xrek/' rel=''>@xrek
    when assigning material orientation, make sure the direction is not perpendicular to shell elements, whose IDs are reported with the error.
Welcome!
Welcome!
