🎉Community Raffle - Win $25
Join and Win
Yield and Ultimate Strength
User: "Anıl Türkseven"
Altair Community Member
Updated by Anıl Türkseven
Hello, How can I add Yield and Ultimate strength? My material is isotropic so ı will use Mat1 but I didn't find yield strength section.
1 - 4 of 41
    User: "NickZ"
    Altair Employee
    Updated by NickZ
    If you're looking to add a non-linear material to your model you can use the MATS1 option on the MAT1 card. In order to include that material in a non-linear subcase you'll need to add a NLPARM card to the subcase.
    OP
    Thank you, but My material is Inconel 718 and linear. I want to add those properties for topology optimization and safety factor.
    User: "NickZ"
    Altair Employee
    Accepted Answer
    Updated by NickZ
    I see, in that case you don't need to change anything with the material property itself. You can just add a design constraint to the topology optimization problem. You can add stress constraints by property or element sets using a DRESP1 static stress response. Or you can add a global stress response on the topology design variable.
    Here is a tutorial for the global topology stress constraint:
    https://2019.help.altair.com/2019/os/topics/solvers/os/hook_with_stress_constraints_r.htm
    You should look into attending one of the Optistruct for Optimization classes, we cover this in detail.
    OP
    How can I attend the classes ?
