Analysis of a cylindrical rod
Mr X
Mr X New Altair Community Member
edited July 2021 in Community Q&A
material1 - AISI 4130 , Outer diameter =31.75mm, THICKNESS = 1.6 mm
material2- AISI 4130 , Outer diameter = 25.4mm, THICKNESS = 2.5mm
can someone use hypermesh to calculate the max stress induced, yield strength, ultimate strength  of both the material cylindrical rod
Answers
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited July 2021
    hi,
    can you detail a little bit more what you need?
    Yield and Ultimate Strength are material properties.
    What are you trying to accomplish? Maybe adding a few pictures would be helpful as well.
Welcome!
Welcome!
