material1 - AISI 4130 , Outer diameter =31.75mm, THICKNESS = 1.6 mm
material2- AISI 4130 , Outer diameter = 25.4mm, THICKNESS = 2.5mm
can someone use hypermesh to calculate the max stress induced, yield strength, ultimate strength of both the material cylindrical rod
