How to simulate rubber material for solid element in NVH simulation?
Hello,
Currently I am building a VTF simulation model to calculate vibration and I am having a hard time simulating the rubber material for the solid element of the damper. I can simulate rubber material through 1D element - CBUSH, but with solid element I really don't know how.
I want to ask if it is possible to simulate elastic material like rubber for solid element? and if so, how?
Thank you very much.
- Mooney-Rivlin
- Yeoh
- Arruda-Boyce
- Ogden
- HyperFoam
- Several other types of mathematical models.
Hi Tung,
You can use hyperelastic materials for rubber.
OptiStruct support some models of hyperelastic materials:
You can create hyperelastic material through MATHE card and PLSOLID for solid element as an image below:
Thanks.
Hi Brian,
Thank you so much for answer my question. I have also read through a few documents related to elastic material simulation through the MATHE card. But it seems this card is only suitable for nonlinear simulation, while I am doing VTF simulation. Perhaps using 1D element as CBUSH and CVISC is suitable for simulation for rubber material.
Thanks.
Hi Tung,
Thanks.
