Hi @Rahul_P1, I am using a student/academic licence to run the Feko suite, but it seems that the licence is not activated for WRAP. This issue has been discussed in other posts on the community, but has not been solved:
The following error is issued:
There is no issue running all of the other Feko components nor the WinProp components. It is only when running WRAP.
Could you please check on this?
Thanks
