SIMLAB Frequency Response Analysis - FATAL ERROR "eigdrv", OptiStruct Error "3428"
I am running a modal analysis/frequency response analysis. I am using the same meshed components from a previous, successful analysis run; but I replaced 2 meshed components with updated CAD changes. I cannot see anything wrong with the meshes or the set up. However, the analysis keeps failing and the only explanation in the 'out file' is Error "eigdrv" and OptiStruct Error "3428". Does anyone know what these errors mean or reference?
1 - 3 of
31
1 - 1 of
11
Hi Adam,
Please share the .fem and .out file.
Which version are you using?
Thanks
Rajashri
Hi Rajashri,
Through trial and error I have resolved the issue. it was a fault in the tet10 mesh for the imported component. I re-meshed to tet4 mesh and it seems to be working now
Hi Adam,
Thanks
Rajashri
