I've recently switched PCs due to hardware issues and cannot deactivate the license on the old system.
Hi @Nikhil_237
Your previous license key activation is now deactivated in Altair one, you can now reactivate the student license with the same license key.
Deactivation and reactivation feature is only if a computer breaks down or reformatted and is only allowed a few times per user preprogrammed into the system.
You can deactivate the license from one machine and reactivate in another by yourself if you have access to both machines as per – https://community.altair.com/discussion/34280/altair-student-edition-deactivate-from-one-computer-to-activate-in-another-in-the-rare-case-a-computer-is-lost-or-malfunctional#latest
Thanks!
I have the same issue, maybe you can help me out as well.
Hi @LukasSin
Hi @Ankita_v,
I have the same problem! Could you deactivate my old license please, so that I can use it on my new PC? Thank you!!
Hi @CarlosKH
I have the same issue.Could you deactivate my old license please? Thank you!!!!
Hi @mss15m
