Ideal Gas Compression in an Actuating Piston
Hi Good day,
I am currently working on a CFD analysis of a cylinder and piston assembly, using the AcuSolve Ideal Gas Compression in an Actuating Piston tutorial from SimLab as a reference.
Following the tutorial, I have created the fluid domain and generated a table that defines the piston motion based on a mathematical equation. I plan to apply this motion as a translational mesh motion in the simulation.
Could someone please explain the steps shown in the image above?
Specifically, under the Nodes section:
- Mesh Y-Displacement
- Type: Linear
- Mesh Motion: Piston
- Curve Fit Variable: Y Reference Coordinate
- X1: 10.0 m
- Y1: 1.0 m
- Y2: 0.0 m
What do these terms represent? Why is X1 set to 10.0 and Y1 to 1.0?
Thanks & Regards,
Sivaprakash.
Hi ,
Thanks for your reply.
I am clear why we use that option and created a table.
But I am confusing, why we assign Y coordinate as 10 .
Because, I am trying simulate the similar model and the fluid domain length is 16mm.
I assigned the rest of boundary conditions similar to the tutorial.
But I can't get the results, the mesh didn't move.
So that I am confusing about it.
Thanks & Regards,
Sivaprakash.
Hi,
I changed the Nodal Displacement - Coordinate reference values for my geometry.
Now, It working fine.
Then in the Mesh motion, We select the face of moving body and select the direction then assign the piecewise linear curve & set speed.
In the tutorial, the speed is set as 1m/s. Is that speed matches the Time vs Displacement table.?
Else we need to manually calculate the velocity of piston then enter it?
Which one is correct?
If the speed is constant, just set the speed. If the speed is changing - it depends on what you know.
If you know the time vs speed - use that option in the Create Table panel - and the software then determines the displacement.
If you know the time vs displacement - use that option in the Create Table panel - and the software then determines the speed.
You wouldn't specify both.
The idea/intent is to control the motion of the rest of the mesh by scaling the mesh motion applied to the end face of the piston. Y-Reference-Coordinate is the y-coordinate at the start of the simulation. The moving face of the piston starts at y = 10, with the fixed base at y = 0. We want the moving face to move exactly with the defined mesh motion - so scale factor = 1, then we want the other base not to move - so scale factor = 0.
The first column is the y-reference coordinate, with the second column being the scale factor for the linear fit to the defined mesh motion. So we should have:
X1 = 10
Y1 = 1 (so at y-reference-coordinate = 10, the linear scale is 1 - move exactly with the mesh motion)
X2 = 0
Y2 = 0 (so at y-reference-coordinate = 0, the linear scale is 0 - so no motion - with linear fit in between)
From the HyperMesh CFD setup:
We need to correct the documentation to have X2 = 0, Y2 = 0.
X1 = 10
X2 = 0
