Plastic strain
Dear Altair team,
For shell analysis, after plasticization, do I need to use "Equivalent plastic strain - EPS" or "VM plastic strain"? It looks like these 2 values are not the same.
What is the best value to consider to have a valid level of plasticization?
Green: Element strain
Blue: VM plastic strain
In this example, how can the EPS be higher (x3) than element strain?
Best,
Axel
1 - 1 of
11
Hi Axel,
equivalent plastic strain, and VM plastic strain are not computed in the same way. You can find details in this discussion:
The 3x difference in your graph indeed seems a little bit too high. Can you request strain at gauss points and re-evaluate? Also check shell formulation you are using.
Kind Regards
Alberto
