Plastic strain
Axel_A
Altair Community Member
Dear Altair team,
For shell analysis, after plasticization, do I need to use "Equivalent plastic strain - EPS" or "VM plastic strain"? It looks like these 2 values are not the same.
What is the best value to consider to have a valid level of plasticization?
Green: Element strain
Blue: VM plastic strain
In this example, how can the EPS be higher (x3) than element strain?
Best,
Axel
Hi Axel,
equivalent plastic strain, and VM plastic strain are not computed in the same way. You can find details in this discussion:
The 3x difference in your graph indeed seems a little bit too high. Can you request strain at gauss points and re-evaluate? Also check shell formulation you are using.
Kind Regards
Alberto
