I apologise if the topic has already been covered. As part of a master's thesis, I am working on a complex model consisting of several components. The deformation of one of these must be transmitted to another, so that the latter also deforms. The model can be simplified as follows: two plates are placed consecutively. Let 's consider a force applied to the left plate, as in the first picture. As the left plate deforms, it should touch the right plate and deform the latter. As shown in the second picture, however, the left plate penetrates the right one without achieving the expected behaviour. What could be the solution? Thank you for your support.
