Is there any quick way to change drag direction
Description: [Is there any quick way to change drag direction]
Product/Topic Name : [Hypermesh 2023.1. ]
*Note from Community Team - Once you receive a satisfactory answer on your question, kindly mark your answers as "Accepted" so it can help others with similar problems. Thanks.
1 - 3 of
31
Hi,
While in the Along Vector tool in the Microdialog window, it will be the fastest method to give orientation with CTRL + left mouse button. This way you can quickly change the extrude direction.
